Find below the TNG USB buffer drivers for use with Windows 8 64-bit .
NOTE: Your TNG USB buffer requires programming for Windows authentication to allow install of drivers. Refer to TNG USB Buffer on Windows 8 and newer
Unrar, the password is ‘datatex123’:
Windows 8 Drivers.rar (980.4 KB)
Install procedure:
- Unrar the drivers and save on TNG PC.
- Unplug the USB buffer cable and re-connect:
- if no drivers installed it will give message that new hardware was detected. Use the option to browse to where you extracted the 64-Bit drivers (do no user Windows default drivers) and install.
If installed correct it will list the buffer in Device Manager under Universal Serial Buscontrollers and Ports (as comport). The drivers converts the USB port to a COMP port. - If no popup for new hardware go to Device Manager and uninstall the USB buffer drivers. Once buffer drivers listed for USB and COM ports, please install as described above.
Also see: My TNG buffer is not being detected
