Open the TNG web page
Enter the General settings icon
Enter the technical password required
Once logged in, scroll down to the communication mode screen
- ‘NETWORK’ is selected the following will be displayed:
- Set PABX IP to that of the PABX.
- Set PABX port to the port of the Mitel PABX (default is 1752)
- Untick ‘Keep alive’
- Tick ‘Idle Disconnect’.
- This will ensure TNG re-connects to the PABX, for example if it does a maintenance reboot.
Plugin: PMitel_3300icp certified.dll
Also see forum post:
- The PABX must be set to output the standard format:
MITEL 3300ICP standardized settings - Example of certified format:
MITEL 3300 Certified format
