TES: Add extension
TES receives all data from the PABX.
The extension needs to have made/received a call already to be available for allocation.
The extension is allocated to a user and therefore the user’s branch and department must exist already.
  • To view if the branch exists or add branch:
    Log in as TES admin.
    Go to Settings.
    Branch/Rate setting.
    Click on button add branch.
    Very important: put in local/national/mobile cost (copy from previous branch entry).
    Make sure that the relevant departments are selected.
  • If you need to add a new person.
    Go to MyCalls (left of users tab), after clicking it will show Main.
    Enter extensions to search under MAP VALUE and PREVIEW.
    If found, please update branch/department/user name /user ID - if used.
    NOTE:
    If the entry is in red - then it has not been allocated yet,
    if black it has been allocated - then no action required.
For future reference: USER tab.
The user will be available under user tab for maintenance, for example user name change/e-mail etc.
NOTE: To pull reports you need to log in as a user profile - not admin.
