These are the supported formats of the recordings used in the JIBE solution.
.wav files: Linear PCM, 8000 Hz, 16-bit, mono
.al files: raw A-Law files, which don’t contain a header
Preferred format is alaw.
Converting the file in Audacity to 16 bit aLaw:
- Open the recording.
- Use the drop down menu on the top left of the wave form and select “Split to Mono”.
- Now you can delete one of the wave forms, you only need one.
- Use the Drop down menu again and select the “Format” and select “16 bit PCM”.
- Click the “Tracks” and select “Resample” and select 8000.
- Set Project Rate (Hz) to 8000
- Now Select File and “Export Audio”.
- Select “Other Uncompressed files” as the type.
- Click the “Options…” button and select Header as “RAW (header-less)” and Encoding as “A-Law”.
- Click ok.
- Change the file extension to “.al” and save.
Converting the file to 16 bit mono wave in Audacity:
- Use the Drop down menu again and select the “Set Sample Rate” and select “16 bit PCM”.
To open the .al files in audacity again
- Select “File” → "Import " → “Raw Data”
- Select the file you need to import.
- Select the following settings:
Encoding : A-Law
Byte Order : Default endianness
Channels : 1 channel ( mono)
Start offset : 0
Amount to import : 100%
Sample Rate : 8000
