VERSION 2.0.6.2
If you are using this facility, you will also need crecallinfo 1.6.6.2 to support these requests.
The Setting to use the EXT@MITEL_IP is set in the mbg.ini file and requires a restart of the recording software.
/opt/datatex/amtmitelcre2/mbg/mbgX/mbgX.ini
In the INI file in the [MBG] section you need to add the USEIP and set it to 1
[MBG]
USEIP=1
The extensions then needs to be added with the format:
EXT@IP=
Like this:
3000@192.168.15.2=
This vrsion also supports adding EXCLUDED extensions to ensure that you can set RECORDALL=1 and still manually exclude some devices from being recorded.
Ensure that you use the same format as the [EXTENSIONS].
[EXCLUDED]
1329@192.168.15.22=
