Auto upgrade on a non-SLA client
First get remote access to the site.
Make sure Logistics have enabled SLA for this client temporarily
At this point run appstatus on the Amethyst server to see the current versions.
This upgrade will update the Amethyst software to the latest versions.
cd /opt/datatex/autoupdate/
ls -lh
Result must look like this
total 4.6M
-rw-r--r-- 1 root root   73 Feb 26  2025 amtbe.ini
-rwxr-xr-x 1 root root 3.2M May 11  2022 autoupdatesoftware
-rw-r--r-- 1 root root 3.5K Aug  5 09:05 autoupdatesoftware.ini
-rw-r--r-- 1 root root  129 Jun 20  2019 autoupdatesoftware.ini.10000
-rw-r--r-- 1 root root  371 Jun 21  2019 autoupdatesoftware.ini.10210
-rw-r--r-- 1 root root  371 Jun 22  2019 autoupdatesoftware.ini.10217
-rw-r--r-- 1 root root  371 Jun 27  2019 autoupdatesoftware.ini.10219
-rw-r--r-- 1 root root  663 Jun 28  2019 autoupdatesoftware.ini.10220
-rw-r--r-- 1 root root 2.4K Jul 13  2019 autoupdatesoftware.ini.10221
-rw-r--r-- 1 root root 3.0K Aug  9  2019 autoupdatesoftware.ini.10223
-rw-r--r-- 1 root root 3.5K May 11  2022 autoupdatesoftware.ini.previous
-rwxr-xr-x 1 root root 1.4M Apr 20  2022 autoupdatesoftware.previous
-rwxr-xr-x 1 root root 1.6K Aug  5 03:08 checkforupdates.sh
-rwxr-xr-x 1 root root  403 Jun 20  2019 dosoftwareupdates.sh
Run the dosoftwareupdates.sh script to execute the upgrade
./dosoftwareupdates.sh
This will execute the upgrade which you can view in the autoupgrade log
tail -f /opt/datatex/logs/`logdate`/autoupdatesoftware.log
Look for the DONE message to see once it is done with the upgrade
2026-08-05T09:05:15.012320+02:00 amethystvm autoupdatesoftware: [Info] getexternalresults...hostname parameters= -I | awk '{print $1}'
2026-08-05T09:05:15.017369+02:00 amethystvm autoupdatesoftware: [Info] param...-V
2026-08-05T09:05:15.017490+02:00 amethystvm autoupdatesoftware: [Info] ***DONE***
Run appstatus again to see the the software versions have updated
